E220cdi. Starts and runs fine untill 2500rpm ??
steve hw
Norwich, Norfolk
Hi. Have a problem with a e220 cdi (210) model 70,ooomiles. Starts ok, but then idle speed tends to dip quite lowfor a few seconds.If you attemot to select reverse or drive it may stall. If you rev the engine all seems fine untill around 2500rpm. Then it seems to miss fire and smoke from exhaust Grey/blue ish in colour but smells diesely. Have replaced mass air sensor, changed fuel filter, run from lifeline (fuel can) disconnected front cat from turbo, disconnected egr valve. No different. No fault codes. Any ideas. If you drive car gently nothing really appears untoward. Many thanks in advance of any ideas ???
Xtractorfan
S class
You may have a faulty inport motor or the linkage may have come adrift,
jameezzzz
Got the same problem with my C220d, but starts with the smoke and the missfire @ 2000rpm! anyone out there that has found the cause to this?
Cheers,
James
www.ckinsurance.co.uk
