spitfirecbs
- Jun 8, 2003
Hi all - 1st post, had the car 3 weeks and so far so good. I've noticed that the front suspension squeaks, a bit like an old metro , when going over a bump or speed ramp etc. It only seems to do it when it's dry, so I have tried bouncing the front and squirting water over various bushes at the front, but I could not get the squeak to go.
I think it could be the front shocks, it's on both sides and quite loud (from inside and outside of the car).
Any ideas ?
Also noticed that the rear shock pipes (load leveling susp.) look quite rusty and corroded - is this worth worrying about, or do they all look like that for ages ?
Lastly, the cruise control doesn't work. MB garage said they'd have to hook it up to the computer - ie. expensive. Any common faults? I can't believe it's the actual switch failing in all 4 directions... stepper motor perhaps (the throttle is a bit sticky from idle) ?
Cheers,
Mark.
Any ideas ?
Cheers,
Mark.
