3898johnm
- Dec 23, 2008
- Location
- Essex
- E220....124 E230....210
Sometimes one's mind goes blank.I was underneath the car today and just generally givinig it a visual when I suddenly wondered should there not be an under-the-engine cover with a profiled cut out round the sump for access . I know there are many different engines with the 210 bodyshell.On mine there is no cover from behind the radiator so with the bonnet up you are looking down at the tarmac or when underneath looking up through the engine at the sky. I wondered if at some time there was a cover and it was removed for access to fit a new ball joint or more recently a water pump,belt tensioner and fanbelt. Has anyone got an e230 1997? I would appreciate advice.
