E240 w210 fan
duc600ss
I am about to change my water pump and using the wis instructions from a dvd. It tells me to remove the viscous fan from the front of the water pump after I remove the belt. Problem is there isn't a fan on the engine only an electric one behind radiator... Does anyone know of a modification to remove this fan or has a previous owner lost it?? I've never had any overheat issues at all ,only changing pump as its getting noisy.
1998 E 240, w210, 911 eng
Yes do not worry, this was deleted after a water problem that shorted out the control unit that in turn stopped the car, as it was wired across the engine ECU.
Enjoy your car :D
D
duc600ss
Thanks for the info, just got a little concerned back there.
Regards
www.W140.co.uk&www.r129.co
