Jonners2022
Registered
- Sep 1, 2022
- E250 Diesel Estate - 2012
My car is in a local independent. They changed front discs and pads, and also rear brake pipes that had corrosion and failed MOT.
Job has been done but they are struggling to get the right resistance / hardness of the brake pedal. Suggesting ABS block / pump may need to go to a specialist. Valve may be malfunctioning. Brakes were fine when taken in!
Any thoughts on what the problem could be. I would like to give them a steer if possible to try and eliminate 'trial and error' leading to more complex problems. I have read the forums and consideration should potentially be given to:
- Use of a pressure bleeding system needed
- Possible need to use MB Diagnostic system to bleed ABS pump
- Air or contaminants in Master Cylinder
- Traditional bleeding, by pumping pedal may have damaged Master Cylinder seals, now allowing bypass?
Any theories or help appreciated
