E300 and SVO – bit the dust. Goodbye to Mercedes forum over the years.
pcman_jh
Haddington
2013 E220 Cabriolet
My 1999 E300 has finally bit the dust. I’d converted it to a 2 tank Veg oil kit in Sept 2006, and having done about 35000 miles on the kit. Over the past 2 months it’s had a noticeable loss of power - sometimes struggling to get to 50 MPH on a straight road, with slight incline. I’d also been experiencing oil consumption of about 0.5 litres a month for the past year, although no smoke out of the back. It has also been showing signs of backpressure in the engine as there would be oil leaking from the oil filler cap (which is well screwed on!!). Strangely it’s always started 1st turn/touch of the key, even when cold – which suggests compression was fine.
Anyway, a week past Friday I thought I’d give it an Italian tune up to resolve the flat power. On fairly heavy acceleration up to 80 MPH there was a huge white smoke plume from the front of the car, then a smokescreen for about 200 yards, then the smell of engine oil! During this blow out there was no loss of power from the engine. Since I was only 1 mile from home, I kept on driving. About 200 yards from home the ‘oil at minimum level’ warning came on. On opening up the bonnet, there was engine oil spewed, and I mean spewed, all over the engine bay. The white smoke was obviously the oil hitting the hot exhaust. The oil had came from the oil dipstick which had been push out of its holder leaving the oil to be pushed out the dipstick holder orifice. I suspect I've had gradual sticking of the piston rings, which is an alleged side effect of Veg oil use.
When visiting car garages the next day, to see what I’d get for a trade in, it had a noticeable power loss but was still driveable. Since my replacement car wouldn’t be ready for a week, I tried driving it with the dipstick sticking out of the holder, to help it breath, but this just resulted in more oil being spewed over the engine bay. It drove OK for 3 days with the dipstick back in again, but I intentionally never went above 50 MPH just in case.
I was looking to change the car anyway as I’d had it for just over 2 years, with the preceding months running it on a mixture of SVO in the tank. The main reason for looking for another vehicle was the alarming rise in SVO cost. It was 49p litre about 12 months ago. It’s now 86p litre which meant my company mileage rate wasn’t covering the fuel cost since I was getting 30MPG (remember it was a 3 litre). The blow out forced the issue of changing car. I got £3000 for a trade in which was the best I was offered – not telling them it had been converted as they’re only interested in age and mileage, then straight to auction. The worst value was £1400 against a Mini.
I removed the 2 tank kit, which is currently on ebay for sale. It did sell for £387, but the guy used a robot which set his max bid to £187,000!! Hence it’s being relisted tonight at 9pm.
Thanks to everyone who has responded to my questions over the last 8 years. I’ve also had a C Class (W202 model C250) which was also run on SVO, then a A Class for a year, before my E300. The forum has been invaluable.
I now have a 2 litre Golf Plus TDI. No doubt I’ll be back…
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Sorry to hear about your loss :(
All the very best with the Golf - good choice, by the way.
Wishing you many miles of safe motoring - hope to see you back soon.
karlefr
w213
What a waste! What's wrong with Diesel?
Parrot of Doom
Manchester
Genuine question here but why would sticking piston rings cause oil to come out the dipstick tube? What engine oil had you been using?
It sounds quite bizarre to me (and not terminal).
Xtractorfan
S class
Basically when the piston rings stick the pressure from the compressed mixture of fuel and air leaks into the sump and causes pressure build up which in turn pushes the oil out thru the dipstick tube...
Parrot of Doom
Manchester
Ah so the rings don't expand to seal the piston, and the gasses get into the crankcase.
Still, not terminal. Bit expensive to fix though, unless you could pour something into the cylinders and let them soak, to break the carbon up.
Xtractorfan
S class
Yes normally diesel tho there are oils for the job great stuff this diesel
Broken rings or bad gapping causes crankcase compression, that will blow the oil out through the front and rear main bearing seals and the dip stick
www.W140.co.uk&www.r129.co
