jbrameld
- Oct 7, 2017
- E300 Estate Hybrid 2014
I have a 2014 E300 BlueTEC hybrid Estate (S212 I think). For some time now the stop/start has only worked very occasionally if it's not too cold and I have driven a long way. I have also started getting some red 'see owner's manual' battery warnings which have become more frequent as I am not using the car so much in lockdown.
The hybrid system seems otherwise OK with good charge levels indicated on the hybrid battery and boost provided on acceleration, so I don't think the problem lies there.
From some searching, it seems like the stop/start battery could be on it's way out - it is the original OEM unit (so nearly 6 years old) and it's located under the boot floor so very easy to get to. It's an 019 size AGM battery, replacements seem fairly easy to come by and the physical swap would be easy to do.
I have read some stuff online that indicates that a coding or registration procedure might be necessary but I haven't found anything definitive. I can stick a donor/starter on the jump terminals so the system won't lose all power but can anyone advise if a coding or registration procedure is required, and if so is there anyone no too far from Rickmansworth that might be able to help me with that?
Thanks,
Jason.
Thanks,
Jason.
