I know it sounds obvious, but have you checked yellow pages under Diesel Fuel Injection. They usually list wholesale suppliers who would sell you a set at much less than stealers.
I think with those injectors you can get them reconditioned - I think it's called retipping - for less than you'd pay for new ones. Try a local diesel / truck specialist as they'll do it all the time for trucks. So long as they check the spray pattern & opening pressure they should be fine
BTW, what makes you think the injectors need replacing?
During a visit to my local Merc dealer ,Isought the advise of a technician, who advised that it was a dieslel knock , although intially I thought it could br a tappet.I listened to the injector lines using a stythescope and there is a noticable knock , so I will go with the advice
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
