e300 td head gasket
gazz1969
dorset
clk 320 2003 convertible
hi all looking for information on doing the head gasket on my e300 turbo diesel 1998 anything to avoid anything to check
also where can i get the tool to remove the injector pre chambers and hints on timing it all back up many thanks
You can tie the chain to the cam wheels to avoid upsetting the timing.. the chain tensioner has to be removed.
Take care of all vacuum pipes and note where they go.
If you cant get to the rear exhaust manifold bolts take off the down pipe and remove head complete with manifold
Some others should give you some more info
G
gazz1969
dorset
head is knackered warped not cracked though have sourced a replacement and should be rebuilding soon
Tel: 020 8863 9233
