comfort zone
I have a 1997 E300 TD auto with electronic Bosch fuel delivery pump.
The car runs very well before it completely warms up to normal running temperature, about 80c. At that temperature it accelerates and pulls well, the problem manifests when taking your foot off the throtle and slowing down. The engine appears to misfire and there is a noticeable "wobble" from the engine as the revs drop. When arriving at normal tick over speed the engine again runs smoothly.
With the car stationary you can, when it is at normal running temperature, rev the engine and see and hear this "misfire". Untill the engine is at normal running temperature this does not occur.
The fuel pump has been removed and examined, re calibrated, adjusted by a reputable diesel engineers and this makes no difference. Bosch technical department have been consulted and they can offer no help. The ECU has been replaced and checked. The vehicle shows no faults on diagnostic test equipment! The gearbox and torque converter oil has been changed and so has the gearbox electrical connector housing, there are no faults! There are no leaks in the fuel system, but the problem persists.
It has cost a lot of money so far and I am no nearer now to finding the fault than I was 2 months ago. If there is anyone out there who has any practicle suggestions I would be pleased to hear from them, so would the diesel engineer!
Thanks, John
Thanks, John
