crt
- Apr 22, 2005
- '95 E300D estate, '16 Golf, '58 Unimog 404, '95 Defender CSW
- Thread Starter
- Thread starter
- #21
Now, I've stripped the duovalves down and they appear to be working - the pistons run freely and, when turned upside down (pistons sticking up) and reconnected to the power, they pulse up and down depending on hot/cold settings.
I then flushed out the heating circuit by connecting a garden hose to the hot feed from the engine block. Finding the right pipe took a couple of goes - there is a y branch just after the block, with one side going to what I think must be the matrix and the other going to what I said in my last post was a bypass returning to the duovalve/recirculating pump.
When connected to the matrix pipe, gungy water gushed out of each duo-valve aperture, and then shortly after ran clear.
I reassembled everything (predictably breaking one of the coarse thread screws that others have warned about) and, lo, I had heat once the engine heated up.
However, it went cold again after I topped up the reservoir. At time of writing it remains cold but I am going to tinker some more.
If anyone has any further thoughts it will be appreciated.
