E300TD main Beam Relay
isbcs
Hi, does anyone have access to a wiring schematic for a 1999 E300TD please and can tell me where the Main Beam relay is located in the car?
The symptoms are that main beam does not work when selected but the main beam flasher is fine. I assume there is a relay in the circuit somewhere.
Many thanks
Tom
I
isbcs
Hi, by combination switch do mean the main switch on the steering column?
I also think it must be the main combination switch as I cant find a relay.
230K
Belfast
E300TD/1998/3.0 Diesel
I dont think there is a main beam relay on the E300TD, it is something that i always thought MB was poor at. The Japs nearly always have them on theirs but any of the 201's, 202's 124's or 210's i have encountered dont have them as far as i know.
Fitting relays next to the lights really helps the voltage at the bulb and obviously the brightness too.
230K
230K
Not too bad with Xenon due to the lower current, a bit hard on the switch without a relay
I
isbcs
Thanks guys, is the combination switch a servicable unit or is is a complete replacement?
Thanks again
Tom
Hi Tom, a complete replacement
I
isbcs
Thanks Malcolm. Sounds expensive!!
I
isbcs
Thanks George.
Tom
John G Martin
Kelso Roxburghshire Scotland
WWW.whitehillfoot.com
Hi Tom,
I have a problem like you had on your E300TD my E320cdi has a high beam problem also that most of the time it will not go on high beam, then for some reason works fine, like you thought relay problem, the car has only 60K and would not have thought it would need the combination switch but after reading the replies you had perhaps it needs one.
Did a new one solve your problem? and is it poss to replace it yourself, have never removed airbag before? a reply from you would be great, thanks John
Afraid this car has to go my first and last merc
Tel: 020 8863 9233
