e300TD Steering damper
dirtymonkey29
Does a 1999 V reg'd E300 turbo diesel (W210) have a steering damper? If so where will i find it? does anyone have any pictures?
thanks in advance.
230K
Belfast
E300TD/1998/3.0 Diesel
No steering damper that can be replaced like the steering box models. There is bound to be damping built into the rack though.
230k
What are the problems
D
dirtymonkey29
i think my problem is ARB bushes and bottom ball joint. basically when driving over bumps and uneven roads i get knocking noises like the shocks are knackered, and i have to keep a tight grip on bad roads because the steering wants to follow the bumps and grooves. when coming back into the inside lane on the motorway if i run over lorrys tram lines in the road i feel like im going to be thrown off the road. had shocks check and there all fine, no leakes etc. ive priced up the parts i need from mercedes and they seem very cheap to be honest.
am i on the right track?
BlackC55
South coast
C43
Yes you are.
What wheels have you got?
BTW they do have steering dampers. Its intergrated within the rack.
BlackC55
South coast
C43
Get a wheel alignment done after the suspension work has been carrie dout.
D
dirtymonkey29
is it better to get lazer alignment?
nice website by the way.....can i suggest a slight mod?.....would be nice to open your "prestige services" photos of your workshop.
thanks for you help
Parrot of Doom
Manchester
Laser alignment worked brilliantly for me, it made the car go from driving a mattress to driving a train.
Expensive but worth it - make sure you get any suspension work done before the alignment. Bushes, ARB links, etc.
The knocking is almost certainly the ARB links. Very simple job and cheap.
D
dirtymonkey29
how many ARB bushes will i need? is it 2 at the front and 2 at the rear?
