E320 cabriolet panel removal for extender investigation.
mtinlin
Woking
E320 Cabriolet, 300TE 24v, E230, Subaru Legacy Estate
Hi, I am in the process of finding out why my seat belt extenders are not functioning. I need to remove the side trim panels. Does anyone have a parts diagram or description of how to remove the trim panel please? I attach a photo of progress so far.
Why not put you Email address in your profile,,then I can send you lots of instructions
Alex Crow
Super Suffolk
do they work at all, or make any noises?
M
mtinlin
Woking
Thanks Malcolm. e-mail address is set up in my profile.
The car is relatively new to me and neither extender works at all.
Sorry you did not click on the save button at the bottom of the page
M
mtinlin
Woking
Hi, I now have the passenger side extender mechanism out of the car. The motor works but the plastic gear and extending arm are worn to excess and need replacement. I doubt if this will turn out to be the only issue but does anyone know if spare parts are available anywhere?
Thanks.
Just seen the Email that you sent me and I have sent you 7 Emails with info
Alex Crow
Super Suffolk
the gear wear is very common, hence me asking 'do they make any noise'. sadly you will find MB unable to supply just the gears.
M
mtinlin
Woking
Here's an update for what it is worth. I exposed both seat belt feeders and the single controller for the car. I need to repair or replace the passenger side feeder mechanism due to the worn gear. I need to replace the related plastic rod that extends out from the mechanism. The controller is situated in a well under the rear seat. It appears to have water damage and I guess also needs replacement. To replace with new from MB will be £305, £55 and £165 all plus VAT respectively. In my view this would not be 'economic'. I guess I am going to have to hunt around for used parts. 'Not the worst thing that could happen I suppose. I attach photos in case anyone can offer any advice.
Cheers.
Pleased that you are getting somewhere,,though the price for parts is silly. I presume that the parts are handed looking at the picture. So Alexander was spot on here.
One from a breaker in the USA would be more worn.
M
mtinlin
Woking
The motor mechanisms are handed, but of course the motors, gears and switches are the same for both sides. This model has a single controller whereas some have a controller for each side mounted on the mechanism.
tamgas
herts
e220 cab
Hi,My feeders dont work either.I have them out of car,how do you replace small cogs ? I have been told cogs from an s class fit? as mercedes want a fortune for new units. Very grateful for any advice .
M
mtinlin
Woking
I had some cogs made to repair my seat belt extenders and have some for sale. PM me if you are interested.
tamgas
herts
e220 cab
How do i pm you ? i cannot find your address anywhere. Also dead impressed you had cogs made!
Sorry you have not been a member long enough to be able to PM
If you care to pop up your email address I will contact him for you,, you can edit out the address within 4 hours of posting
OK I have sent him a PM with your details and interest.
please remove your address in edit :D
www.W140.co.uk&www.r129.co
