colin carnegie
- Jan 29, 2008
Just thought I would share this with you, as I think ever little bit helps. Some of you may have seen or used / using these things before, they are called Magnetic Fuel Conditioners (MFC’s)
Prior to fitting these MFC’s, I did a five tank “brim to brim” test, recording my fuel receipts against the actual mileage. Fitted these MFC’s to each injector fuel line, did another five tank “brim to brim” test again recording fuel receipts against the actual mileage covered, (all fuel was from supermarkets) Comparing the two tests, I am now get an extra 6% from a tank of fuel. Total cost of the 6 x MFC’s was £300.00, at todays fuel prices, I think thats reasonable.
Also these are very simple to install, no cutting into the fuel line, they simply go around the pipe, and held in place with a ty-wrap. Even if you sell your car, you just remove them and fit them to your new one.
I would show you a picture of how they are fitted, but don’t know how to up load a picture into the threads.
Thanks,
Colin.
Thanks,
Colin.
