e320 cdi oil change
ftrottier
Hi all,
Would anyone be able to provide some guidance on how to perform an oil/filter change on my 2001 Y-reg e320 cdi? Have not found anything on the net and there are no Haynes manual either. I have performed oil changes on my other "domestic" cars (Rover, Renault) for years so I think I can get on with this one as well. Also my last B service was an obscene £800 (there was nothing wrong with the car!) so I am thinking to perform the interim services (A) myself, leaving the more exhaustive B services to the main Merc dealer. Any help/guidance appreciated! Thanks in advance.:-D
Cheers,
Franck.
clive williams
ftrottier said:
Hi all,
Cheers,
Franck.
Franck,
If you're intent on diy'ing the services then purchase a pukka Merc manual adverised on eBay. They are cheaper than the pathetic Haynes manuals these days and will cover everything you need to know.
Re the oil change - drain the (hot) oil from the sump after taking the undershield off. The oil plug needs to have its copper washer renewed and tightened to 18lbft. The filter is a typical merc cartidge filter accessed through the alloy cartidge bowl attached to the engine RHS viewed from front. Replace the o ring seals as supplied with the filter. Tighten the filter up to 18lbft again - Job done.
The oil quantity is 7.5 litres of the best - I always use fully synth, as do others on the forum.
Clive
500E
E320CDIT210
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
Dont change the oil spec, fully synthetic, expensive but the engine needs it.
F
ftrottier
Chaps,
Thanks for the responses. For oil - yes - mobil 1 fully synt/0W40 as for previous services. Having changed the oil, how do you then reset the Assyst/onboard computer setting? I hear you have to press the "R" button on the dashboard at the same time as turning the ignition key. Is this correct?
Cheers,
Franck.
