Yes, yet another one.... ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I’ve seen many similar threads here over the last few months. When starting from cold occasionally the car would stick in 2nd, but running the engine for a while and then restarting always sorted the problem.
About 2 months ago it stayed in 2nd however many times it was run and restarted. So took it to a local MB indi who “checked g/b level – ok, checked ECU contamination – ok, carried out short test, inspected stop light switch and replaced, erased fault codes and road tested – all ok”.
And it was well for 6 weeks but then the car “rested” at a main dealer for 2 weeks to have a lot of body work done. Yes the usual rust problem with these cars, new wings, new tailgate, doors and both rear wings repaired. Thankfully all done under the “good will” warranty scheme and the car does look really nice now...![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyway since picking the car up it will not change out of 2nd whatever combination of running and restarting. Have checked the battery voltage at +14v but noticed it did need topping up with distilled water, did this and charged battery overnight. Still no change, voltage is good before and after starting several times.
Is it possible that fault codes are stored up in some kind of history but gets full to a point where they are not reset however you try to restart the car? Is there anyway us mere mortals can reset/clear these codes by some combination of button pushing and key turning, whilst standing on one leg, winking and singing the German national anthem?
Any help gratefully received – prior to yet another expensive trip to the MB money drain.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
