davidpmiller
- May 16, 2006
I have an EClass 320CDI (Reg Aug 2000) -46K Miles
Recently, the car has started juddering badly when at idle. The dealer said one of the cylinders was down (not sure what that meant but it was expensive!!).
They suggested adding some Diesel cleaner, which appears to do the trick for a while. However, it starts again after a few weeks, in addition if the car isn't started for a few days it struggles to start (not sure if it is related)
The last service changed the glow plugs which they said would solve the problem, but it didn't!!!
No warning lights or messages just juddering!! Another dealer suggested it may be a leaky rubber plug that sits on the top of the gearbox, which after 3-4 years this goes hard and un knowing to the car owner, oil from the gearbox travels' up the cables in a capillary way and finds itself in the control box/ecu, this ends up with the gearbox having lots of faults, the only way to cure this is to replace the ecu,and the wiring harness, this is 9 hours labour, @110 the ecu is £600 and the harness is £500 - all in all about £2000!!!!!
Any ideas what the problem could be?
Regards
Regards
