bende1998
- Dec 14, 2022
- 2006 E320CDI 642920
Hello,
I have a W211 with V6 320CDI (642920) and the last week the car went to limp mode. Checked the error codes and the stardiag show these codes:
- 2530-002 M55 (inlet port shut off motor) short to ground
- 2526-002 test signal cable to component Y77/1 (charge pressure positioner) short to ground
- 2527-002 Y27/9 (left EGR) short to ground
- 2376-001 Check component N3/9 (CDI control unit). Control M16/6 (throttle valve adjuster) Voltage too low
Have you ever encountered this error? Do you have any advice or tips on what should be checked or possibly replaced to eliminate the error?
Any advice would be gratefully received, thank you.
