E320CE Dash lights 1993 W124
rjbeston
London
I have looked at a lot of the threads on dashlights and this issue does not seem to be covered.
Basically, there are 2 lights (I think) on the dashboard - one on the left hand side and one on the right hand side as you look at it.
At night, when I have my lights on, The one on the right only comes on after about 15-20mins driving - and then stays on, no problem. When I stop and start again, it goes off and comes on after 15-20minutes. The one on the left is fine.
Dimmer dial works - no issues there.
So I don't want to take it to a garage as Intermittent problems are the most expensive ones to fix - bulb is fine, it just seems to only work when the engine is warm.
Any ideas?
Rob
E320CE 1993 W124
350SL 1972 W107
numbnuts
Banned
Somewhere in the uk
There is a fuse at the back of the dash coloured red it's like a small bulb holder also worth checking connections also change both bulbs
Chazchuzzlewitt
Dorchester
W/S124 320TE Estate
Mine also does this sometimes, I have to tap it like the Millennium Falcon to get it to come on. I really don't fancy taking out the instrument cluster to get to the bulb though.
I've noticed that releasing the parking brake handle seems to affect it so I guess the bulb and/or connection is loose.
turnipsock
Port of Menteith
One of my lights was a bit like that, a good thumb on the dash and it came on. I haven't tried this yet but there is some stuff you can get from Hellfords to smear on electrical connections. It's meant for earthing points but I guess putting some on the bulb would help.
numbnuts
Banned
Somewhere in the uk
The instrument cluster comes out easily
R
rjbeston
London
this makes sense - the dash was loose when i bought it and there were a few screws missing from the handbrake - but I don't fancy pulling out the dash. It's due for a service soon so I will get it looked at then. Thanks for your ideas!
joe bloggs
Bulb for sure, this seems to affect the capless bulbs more for some reason.
