E350 cdi parking brake cable adjuster.
John Judge
Mercedes e class 350 cdi 2011
Evening all. Hoping someone on here can help. Does anyone know where the parking brake cable adjuster is on my E350cdi 2011 is please.
Mark A
Aberdeen
58 ML-320CDI.
Check for an access panel under rear seat base.
John Judge
Hi Mark thanks but tried that. Apparently not for E class models! It seems to be well hidden.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
I was told its under a plastic box section towards the rear . Most folks nip up the shoes to take up slack. It dont take much tbh.
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
On an earlier E class it's under the floor. From underneath, need to remove a cross member with 4 'siezed solid' torx screws and then remove the heat shield. Gave up after removing 1 then breaking a Draper T-bar
John Judge
Thanks for help and advice. As suspected well hidden. Will keep you posted on outcome.
thanks for advice. As suspected well hidden. Will keep you updated on outcome
onefortheroad
uk.
Your welcome
Your welcome
www.ckinsurance.co.uk
