WNX700H
- Jun 29, 2010
- E350 CDi Estate
2010 Nov E350 CDi Estate 30 k miles
Noise is generated when you put vehicle in drive or reverse and with out throttle let the car move , a ticking noise can be heard from the transmission. When you switch the engine off after a few seconds you can hear the same ticking noise decreasing in its frequency ( occurence not pitch ) as what ever is making the noise slows down to standstill .... engine is already stopped by this time.
My logic is it has to be in the transmission as to generate the noise with engine running the car has to move . Ticking noise is not evident once car has any discernable speed. Only evident dynamically when car is allowed to creep forward or reverse
Dealer has been useless in trying to fix this , bought on Mercedes approved used in August last year.
So what is making the noise
