e350 v6 c207 2009
steven.n
llanelli
E350 3.0 v6 cdi 2009
Morning, i have a strange problem, if anyone could advise, I will try and give as much detail as possible.
first start in the morning no problem everthing normal,and can drive for hours, if i drive till the engine temp starts to rise then stop the engine(i.e at the shop/garage) then restart, the car starts but will shut off after a couple of seconds, unless you keep revs at about 1000 for 20 seconds then the car runs ok again.
also if you rev the car in park to about 2.5k and back to idle it will cut out, and when in first at low revs , moving along in traffic it can judder slightly and a little smoke aswell,
Struggling to find someone near me with knowledge of mb, brother in law has a good scanner but not sure what make.
Injectors seem dry and no visible leaks,
anyone come across this before ?
any advice appriciated .
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Possibly dirty/failing crank sensor or cam sensor. Otherwise suspect throttle body or fuelling etc. get a scan for error codes and live data will help.
steven.n
llanelli
thankyou will get it done
