Richard65
- Apr 21, 2018
- Location
- Kent
- 2015 E350 Bluetec AMG Night Edition Premium + 5dr
Can anyone point me in the direction of stock settings for wheel alignment. I have just been for a check and adjust using a Supertracker machine (this was at one of the big tyre/exhaust/brake centre places which will be nameless and I went there only because my independent garage's equipment is not calibrated). When MB told me about the uneven wear at recent service they were not interested in checking and said that it was probably under inflation - it isn't, and just wanted to replace the tyres. Supertracker operative first input the wrong vehicle information and then corrected it when I told him after seeing the read out but when I asked for information about the readings neither he or the manager seemed to know the difference between negative and positive and told me the camber was positive when it was clearly negative on the read out. Only when I pointed this out did they look slightly confused and agreed with me. The short version of this is that on both front and rear tyres both sides wear on the inside edge where the rest of all the tyres is perfectly even in wear. They have adjusted the toe-in front and rear but say they can't adjust the camber or caster. But honestly I'm still not sure if they had the correct settings or if they knew what they were doing.
