Veridian
- May 12, 2006
- Location
- East Devon
- R230...about to purchase will update shortly
Hi folks, Ref my 1998 E430 with climate control - it has a problem similar to other threads Ive noticed.. Since buying the car at Easter the Air con never really worked, just went through the motions but with air at ambient (or hotter if so set) temperature coming thru the vents. Having enquired on the forum around 8 weeks ago I helpfully was told of a site that gives details of the fault codes and various settings. this duly showed there was only 1 bar of pressure in the evaporator.. ie no refrigerant - not really a surprise. I took it along to my reputable independent who plumbed it into their machine which drained, dryed and refilled the system - almost a kilo of coolant apparently, and showed no leaks. System worked fine for a week, but although this afternoon I have just checked, and the evaporator has a steady 8 bar of pressure rising to 14 bar on steady revving - (2500 rpm), and the evaporator temparature is showing 36-40F - nice and cool - im getting only marginally cooler air from the vents, and this elusive 'hissing aerosol' sound from inside the dash, that stops when you hit the EC button, only to restart when the a/c is back on.
I dont think I have a leak - but what is causing this racket - and why am I not getting any cold air!!??.. Any help gratefully received...
FYI - heres the link to the AC info page:
http://www.continentalimports.com/ser_ic40142.html
The Quote below was from wetdog..
Anyone know my problem?
Turn on air con and set the blowers to 3. you hear a faint aerosol like noise coming from behind the vents. Do the same with the air con off and the noise has gone.
Turn aircon on and set it to 6 and when you turn the blowers off the fans stop, as they would, and you hear this loud gas like noise, almost like an empty spray can, coming from behind the vents.
It seems like the gas is leaking or something. I had new gas put in it 2 months ago.
Any Ideas????[/QUOTE]
