Easy headlight restoration in 2 minutes
Morethanpolish
Stamford
CLK 200 Kompressor
We've had this Kit out for a couple of months and its flying off the shelves, due to I think, the absolute breeze it is to use and the mind blowing results anyone can acheive in a couple of minutes.
If your polycarbonate (plastic) headlights are yellowed, cloudy, faded, dull or milky, this is the product for you. No need to pay a detailer to wet sand with 3 grits of paper, machine polish with 2 compounds then glaze, its all in this kit and thats all you need.
See more clearly, pass your MOT and improve the looks of your car with no elbow grease at all. A kit will treat multiple sets of headlamps and costs £18.99 from here: https://raceglaze.co.uk/shop/race-g...stic-rubber/polycarbonate-headlight-restorer/
This is the VW Bora I did a test spot on yesterday and will be featured in Practical Classics next issue.
I also did a section on this SL, which wasnt as bad, but the difference is clear to see:
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Sounds too good to be true. I will certainly consider using it.
Question: does it work on lenses that have already had the sanding treatment in the past, like mine have?
Morethanpolish
Morethanpolish
Stamford
CLK 200 Kompressor
Oh it does what it says, and will work on previously wet sanded lenses
markben
Bristol UK
w220 2004 S320L CDI
View attachment 91464Nice endorsement for your 'clearly' (!) excellent product for most users.
My only word of Caution (from personal experience of un-successfully trying to 'professionally' restore the relative clarity of acrylic / polycarbonate H/L lenses) is that, beyond a point, and due to any or all of ageing, lack of regular cleaning / polishing etc, they can sometimes be degraded despite all efforts to restore them successfully.
Case in point (1): on my 20-year-old W220, a terminally 'yellowed' original (but not misted / cloudy / MOT failure) NSF headlamp lens defied all professional efforts to bring it back to 'crystal clear' whilst the lens on the newer OSF 'only' 12 year-old OE headlamp remains crystal clear with no polishing - only regular washing.
Case in point (2): I recently bought and fitted a new aftermarket 'cheap ebay chineseum' HL Lens which was crystal clear initially.. but yellowed considerably within 2 years despite all efforts to polish & restore its clarity.
After doing some research into the technicalities, I learned that progressive +/- UV degradation of acrylic / polycarbonate HL lenses can.. sooner or later.. penetrate through their entire (approx 5 mm) thickness - and not just through a few microns at the surface. And.. regardless of whether they are OE or aftermarket?
Surface / cosmetic 'Cloudiness & Traffic Haze / Oxidisation' is one thing (& relatively easy to restore?). But deep penetrating and / or long term UV degradation on an acrylic or polycarbonate headlamp lens is an entirely different proposition.
Of course: 'Context is all' and I have no wish to criticise the best efforts of many professional & diligent H/L restorers out there. That said: some (usually online...) claims of 'Magic' H/L restoration services can be optimistic at best, or fraudulent at worst. 'Buyer Beware' etc?
That's my best effort to add some hopefully useful comments to this thread, and hoping it helps for anyone here with a similar dilemma?
Mark B.
Morethanpolish
Morethanpolish
Stamford
CLK 200 Kompressor
Mark, your input is interesting, and I hope we have made clear that propduct is not a surface polish of the more traditional style, used in the typical pro detailers compounded method, but is in fact a penetrative product of highly complex chemistry that does more than simply tittivate the surface ie its a restorer, not a quick fix appearanace product.
And is incredibly easy to do, literally less than 2 minutes per headlight, by hand, with no equipment whatsoever. Its all in the chemistry.
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
I always have my car's headlights wrapped, problem, solved for the life of the car.
Furthermore, you never get issues with stone chips.
Morethanpolish
Morethanpolish
Stamford
CLK 200 Kompressor
Further validation of this exceptional product
markben
Bristol UK
w220 2004 S320L CDI
This (sic) 'exceptional' product sounds good.. for fixing the majority of usual H/L lens 'cloudy / misty' issues. Fair enough.
But..(sorry!): do you have / can you provide any scientifically validated evidence of the chemical efficacy +/- of it on fixing what I can best describe as 'terminally yellowed' (rather than surface 'misted / cloudy / hazy' etc) acrylic HL lenses where UV exposure penetrates through the entire thickness of a HL lens either due to a lack of regular cleaning, ageing or for other reasons (e.g. the quality of the acrylic / polycarbonate lens itself)?
Again: I don't wish to criticise your product & claims unduly. All the same & from experience, I mention this for the benefit of, and in order to share some personal insights with followers here who might be trying to grapple with a 'Terminally Yellowed' HL lens dilemma - and who might not be able to fix it despite their best efforts + with even the 'best' products etc.
In my case, for better or worse?: a new ('cheap' / approx £30) Chineseum supplied acrylic NSF HL lens for my W220 S Class was crystal clear after all efforts to restore the 20-year-old one.
Due to its inferior manufacturing quality & UV resistance compared with OE, it has gradually.. 'yellowed' (but not become misty / cloudy, nor a MOT issue) throughout its thickness over 2 years despite all efforts to polish it. But, by my reckoning: if I need to replace it every, say, 2+ years to keep it crystal clear (& matching the still crystal clear 10-year-old opposite side OE H/L lens cosmetically), that's good enuff for me. And.. far cheaper ££ than replacing the entire HL unit with OE at a cost of £600+. :eek:
Hey ho - that's my best effort at contributing to this thread, for better or worse.
Mark B.
Morethanpolish
Morethanpolish
Stamford
CLK 200 Kompressor
In a word, no.
Producing such data based on laboratory reports would push up the price of the product to a level beyond market acceptability. And I have no idea how such data would be produced anyway.
In your case, £15/year for a clear lens is the way to go unless you fancy trying our product so save yourself that. The Kit should treat about 8 lenses.
Hundreds of users of this products have acheived superb results, thats all I can contirbute scientifically. We are not 3M !
Morethanpolish
Morethanpolish
Stamford
CLK 200 Kompressor
You might recognise the chap doing the video, we have taken this clip from his longer weekly video, with permission.
Morethanpolish
Morethanpolish
Stamford
CLK 200 Kompressor
5* review from customer yesterday having used the product on his C-Class.
the picture says it all...
