Stuhart
- Oct 28, 2021
- Location
- Qatar
- ML63 AMG / 2009 / 6.2litre
I have a 2009 ML63 AMG which I bought a few months ago and from almost day 1 I've been having problems. They started with the car failing to crank and appearing to be stuck in Park though the battery and all other electrics were working fine. Independent Merc garage mechanic (here in Qatar) diagnosed it as a faulty Intelligent Servo Module and replaced it at great expense. Almost immediately on its return it suffered the same issue again. Identical symptoms though the mechanic maintained it was a separate issue from the previous one and said this time it was an issue with the ignition barrel so the internals were also replaced at further expense. And guess what? Shortly after this it failed to start again! Identical symptoms once more. Now the mechanic is saying it's the ECU so I'll need a new of those too. To say I'm skeptical is putting it mildly. It may well be true but then I'm thinking was this the problem all along and the previous "fixes" were unnecessary? However, what I have discovered now is if I disconnect and reconnect the battery it would appear to reset itself and allows it to start so I'm doing this every morning to get it going and living with it like this for the time being while I decide if I really want to throw another sack of cash at a problem I'm not convinced is being properly diagnosed. Does anybody have any experience or an opinion on this?
