If you follow the wire back to instde the bulkhead there is a connetor there that you could test the resistance.
I'm not sure what the resistance should be though. I think the sensor is a coil arrangement, it may be that a digital meter will give some funny readings.
Turnsock is right that it is an inductive device, I think that allowing for the length of the cables, your two fronts should read the same, also the two back ones.
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
