Hi again
Checked voltages tonight, when car first started 14v after a long run 14v. So something not right there. Both of these voltages were with not lights on etc.
Rob....
I cannot see why we now have this voltage fascination, and there are no problems with the voltages being reported here, although 14v at rest is hard to believe.
What read with engine off and ignition on?
So 14V remains all the time? Any fluctuation?like 13.9, 14.2? Have u tried to put load on idle?(radio blower?)
just been doing a internet search, and 14.2 v seems to be the norm.
Has it been checked with the polybelt off?
I'm wondering if it could be an alternator load problem.
All I suggested, was that variable loads on some ancillary component driven by the belt (eg alternator) might give the uneven idling issue.
Running with the belt off will confirm or exclude this theory, assuming the symptoms are consistently repeatable.
Sorry, I am not sure you are up to this.
Fixing cars is hard enough, but without proper diagnostic tools and basic knowledge your chances are too slim.
Releasing the tension on the belt is childs play, just use a 12 point 17mm socket to rotate the tensioner arm aginst its spring.
Do NOT unbolt anything.
Due to mud in "fluctuate revs again" thread here is fresh one
My car c320 petrol 2001, 95k miles
Car runs faultless apart hunting/fluctuate revs on idle and sometimes vibrations
I checked all vacuum hoses few times - good condition
Also cleaned throttle body, maf, sealed breather cover leak, checked everything! Car pass MOT without problems, car feels powerful and accelerate without problem, no codes on diagnostic tool , i/m readiness shows that everything works correctly, o2 sensors work in correct values, no oil leaks
Today I was checking EGR valve.
- disconnecting does not indicate check engine light However was pending code. All clear now
- with correct engine temp vaccum supply was disconnected, no difference on idle, still fluctuation, no vaccum in hose.
- engine revs at 2000- 2500 rpm, disconnecting vacuum supply does not make any difference to engine, there is vaccum in hose.
- with engine off vaccum was applied directly to the valve. Valve holds the pressure.
- engine on, idle - valve is hot but it's tube which goes to manifold is cold.
- engine on, revs at 2000-2500rpm - valve is hot but tube(pipe) only slightly warm.
- also I hit valve by screwdriver few times on idle but no changes.
Egr pipe(tube) - how hot it has to be ?
I would be very thankful for help
