My 1998 C180 is fitted with elec windows to the front only the windows work if you press & hold the switch but if you press the switch down to the speed wind the window jams! do's anyone think that this could be a faulty relay?if so where is the relay housed.The reason I suspect the relay is that it seems strange but not impossible for both switches to be faulty at the same time
