electric gremlin clk
hopeful
clk cdi2.7 auto coupe 2005
ok so an electric gremlin, 05 2.7 cdi . wipers and screen wash refused to work then became intermittent. reset the dash setting worked well , now back to a strange happening. i stopped at the lights and so did the wipers pulled away wipers work as when they choose, screenwash the same . i cannot find a bad fuse or a wire + or- . so if anyone has an idea or something similar please let me know ,any help or input greatly aprecciated , thanks sj
rf065
Grossbritannien
My CLK, the wipers stopped working when stationary, they are designed to do so. Other than that, the wiper stalk is known to fail and may need replaced.
mioba
Nottingham and Köln
So you stop at traffic lights and its raining - the wipers dont work as they are designed not too, You see the traffic lights have turned green through the blurry screen, but you cant see the old woman still crossing as your wipers are designed not to work when starionary
Surely cant be....
hopeful
hopeful
never stopped working when raining even when i stopped at lights or junction ,crazy idea
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Check your battery voltage at tick over.
hopeful
hopeful
thought of that . i shall also try turning the dash auto light etc off , try bonnet catch or go silly and break the mirror trying to get to the sensor
rf065
Grossbritannien
But they do, maybe from facelift onwards, not your 270 old style CLK.
hopeful
hopeful
well just turned all auto functions off via dash ,wipers stopped when indicater turned on , returned dash function to auto as per . still indicater on wipers stop . durr
hopeful
hopeful
c209 2005 ,not old slightly aged like me
this is old
hopeful
hopeful
so if my stalk is faulty would another say 203 stalk work or must it specific
rf065
Grossbritannien
Not sure how pre facelift worked, never had one, but post facelift, if the wipers were on intermittent and you stopped at traffic lights, they switched off until you moved and then became intermittent again. If the wipers were constant when you stopped, they changed to intermittent and so on. They also stopped working when you opened the passenger door to avoid your passenger getting a windscreen full in the face when getting in and out of the car.
Again, from 2005 on, windscreen stalk is a common fault.
hopeful
hopeful
just off the cuff anyone tag an oem no
On my old 202s without rain sensing the intermittent would increase in delay but still operate. If set to low speed they would drop to intermittent. Once moving everything returned to normal.
On the cars with auto rain sensing stopping at lights makes no difference as you'd expect given they wipe when needed.
Your problem does sound like a failing switch but if you have access to someone with star you can test this.
Also check the front scuttle for water.
hopeful
hopeful
thanks all
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
I was just about to post do you know opening the bonnet (on our 07 facelift) will disable the wipers and washers then saw your comment... try bonnet catch ... so assume you have a potential fault in that circuit covered?
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Mine too.
hopeful
hopeful
  • #19
so guys , fumbled about today volts good 14 +, earths relays and fuses look good so going into the car dash autos are all off and i have the same symptoms return auto functions on same again , tried to get to the screen rain sensor yeah later not gonna force that any how by ths time im feeling sure its the stalk playing up after running the engine and using the stalk controls it seems if i hold the stalk in my fist and pull outward to the n/s of car there is some comparable operation and if i push the screen wash it goes cockahoop , but still turns all functions off when i indicate right , seems now i have to take the unit off to see if its five pin or six , just look at the position of those bolts oh great joy , so i have boked a session at the chiro for after to realine my spine ha
just one thing i noticed when repacing the covers with the engine running from cold the damn rad fan is spinning , is this associated or something new like a relay for the fan or the fan clutch maybe the plug in the bumper . i got a hammer ready ,;)
cheers
hopeful
hopeful
  • #20
would anyone be able to confirm if the stalk for lights/ wipers on my 05 clk 2,7 cdi c209 are 5 pin or six . i cant find definite answe on line / dealer may be the way to go but sometimes wont give the knowledge even for my ole girl
