Electric Mirror - ML270 W163
David P
Hi Gang
The mirror on the drivers side. When you adjust it all the way up, it only goes so far and then stops, as if it's not centered correctly. Any ideas? :confused:
Second thing is that when you fold the mirrors in, it folds all the way to the door and tries to go a bit further. It folds out correctly, just not all the way in.
All answers on the back of a used fiver to the usual address.
Many thanks
david
Cosworth
Looks like your mirroe has had a wak at some point. Common problem with the mirror trying to foldin too much. The frame has been damaged and therefore the mirror folds folds beyond.
You need to buy another frame, this will stop that. I may have one.
As to the mirror tilting your motor may be out of place.
D
David P
Without it shutting down like a switched off terminator, how do you adjust the mirror? Do you just push it up a bit?
D
The wires may be positioned incorrectly behind the glass preventing it from moving
