I have a CLK320 W209 series with electric memory seats. The seat electrics are all good, the memory store/recalls all work. In the System Menu I have enabled the feature whereby the key used is meant to automatically recall a seat position, but it doesn't appear to work.
The manual is not very helpful, it merely tells you how to turn the feature on, but not how to actually assign a key to a seat memory.
P92 of manual tells you how to make/recall seat memory positions, as I said this works fine.
P134 tells me how to turn on the keye dependence feature.
I have two keys, I use seat memory 1, mrs G uses 2. But basically the feature doesn't seem to work. Any ideas?
Is the seat meant to move to the desired preset as the car is unlocked? or only after the enginer is started (it doesn't appear to do either).
How do you select which key recalls which (of the 3) memory positions.
Help would be appreciated
