Def_Fid
The motor for fore and aft movement will only move aft, as I presume there is one motor for fore-aft movement, is the fault more likely to be in the door switch, or is there a control relay somewhere?.
Def_Fid said:The motor for fore and aft movement will only move aft, as I presume there is one motor for fore-aft movement, is the fault more likely to be in the door switch, or is there a control relay somewhere?.
