Hello All -
Drivers side window on my 230TE has given up the ghost. The symptoms matched those described in other threads that a search on here revealed: seems certain that the gear teeth on either the motor or regulator or both arestripped or worn, so that although the motor operates, nowt happens.
I am planning to replace motor and regulator with GSF parts, as I can live with the extra noise in order to save £100+ on original parts.
However, one question (that also appeared on the previous threads but wasn't answered):
How do I manually lower the window? - it is stuck in the fully 'up' position and according to Mr Haynes I need to lower it to disconnect the glass from the regulator.
Alan
Alan
