electric window playing up
ady74
manchester
E270 E230 Vito
My electric window yesterday started sticking, you press the button and window goes down 2inches stops then press it again goes down an inch and stops press again and same etc etc same goin up. Just happens on the one window and same happens if use the window button on the door or the button in the front. I read on here on other threads needs resetting by pressing and hold the button at the bottom for ten seconds then the top for ten seconds. But this dint work. Any ideas? its a e230 1997 210.
These motors have a 3 second trip, that is if the window is too tight in its tracts the motor trips,, did you have the ignition on when you tried to re set it.
Or a problem with the rear door ECU that controls this motor.
Alex Crow
Super Suffolk
... I read on here on other threads needs resetting by pressing and hold the button at the bottom for ten seconds then the top for ten seconds. But this dint work. Any ideas? its a e230 1997 210.
Are you aware of the first and second press for the manual/auto function?
If not, try again, pressing the switch only half way down (manual function).
You should also find that with switch pressed half way the window will travel fully up or down without stopping.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Otherwise give the channels a scrub with an old tooth brush in case they're dirty and causing motor, safety to trip.
ady74
ady74
manchester
E270 E230 Vito
yes ignition was on. tried again this morning and window worked fine so thought happy day its fixed over night :) but get to work and started again :-( where is the rear ECU behind the rear door card I take it?
yes was not aware until today but tried this too and dint work sadly.
the channels at side of the window behind door card?
Its all part of the rear door window ECU a combination unit
You have to remove the rear door liner,,I have the instruction if you need them
Often its water damage, it might be possible to clean the ECU up, I do not know as I have not done one of these
brandwooddixon
Wolverhampton
S63 Coupe 2014
I would suggest giving the visible door channels a scrub first. These usually attract dirt that over time gets trapped in the material and causes the window to bind and tripping out the motor safety.
Try with some soapy water at first with the window shut - usually loads of crud comes off and will run down your window and door. Then open the window and with less water work at the inside of the channel.
Don't forget the bottom glass seal either.
If you're looking at removing the rear, door card then check out the DIY thread on how to fit a new window regulator. There's instructions and pictures there.
ady74
ady74
manchester
E270 E230 Vito
yes I should be ok taking card off ill have a look tomorow cheers
ok cheers ill try that too got a day off tomorrow so will give it ago,cheers
ady74
ady74
manchester
E270 E230 Vito
does each window have its own ecu in the doors or they just one that controls all or one on each side of the car?
cheers
The 202 and 210 are unique in having a combined controller for both doors, all other models have an ECU for each door.
If you can get it apart there may be some green algae on the PCB or connectors,, you could was it off with lighter fuel and try it .
ady74
ady74
manchester
E270 E230 Vito
im still struggling with this :-( I can only find one ecu in drivers door and one ecu in passengers side door. ive unpugged both and rear windows still go up and down so were will the ecu be for rear doors as there not behind rear doors? :confused:
Alex Crow
Super Suffolk
I guess yours is the older W210 with key having flip out key blade.
Cannot remember the exact set up on this, but it is not like later CAN controlled cars that have ECU in every door - will see what I can remember...
ady74
ady74
manchester
E270 E230 Vito
no its R reg not the flip key one its the newer key one.
Alex Crow
Super Suffolk
Then cancel that, you have ECUs built into the rear door window motors.
ady74
ady74
manchester
E270 E230 Vito
  • #18
are right so rear motors have ecu built in......so my problem window needs a new motor??
Alex Crow
Super Suffolk
From what you say, yes, as long as the mech and runners etc are all OK and free.
ady74
ady74
manchester
E270 E230 Vito
  • #20
I've cracked it!! I put a second hand motor on today and its worked cheers!!! :D
Tel: 020 8863 9233
