Electric Windows and seats
Irishclk
I have a 01 clk200 conv the front electric windows stop working along with the electric seats, i hav checked the fuses and they are all ok however when this problem happens if i take in and out some of the fuses a few times it comes ok again. Can anyone help btw i have had it checked to make sure there are no loose connections in the fusebox
C200 goblin
St. Vincent
C200, W202. 1998
Dont hold your breath on it.
I am still trying to work out the problem on my C200 98'. At the moment now the front windows and mirrors dontwork.
Even if I pull out the fuses and put them back in nothing. Before the mirrors worked and the front door motors used to click and pulling out the fuses did work them temporary for about a week.
BUt now nothing, virtually given up with them, dont think I would go for a Merc again. I even changed the control panel few weeks ago,no success.
MOB
I had similar problem with my 97 W210 where pass. window and mirror stopped working then drivers and so on,the only way to reset was to disconnect the battery.
I got reply here from Luders79 where he told me to disconnect rear door power, this is located at bottom of B-pillar ( remove the triangluar plastic cover to reveal connector block) do this when you have problem disconnect each door in turn checking to see if faulty window / mirror works again if windows starts working you will know where fault is.
It turned out to be a faulty rear door module which was giving out fault on CAN system causing various systems to shutdown ( even the C/L that was fun!!!!!) or so he said, I just left the rear door disconnected and never had problem again.
Don't know if this is problem but might be worth a look.
