topscalcookie
Has anybody had an abs light on dash stop the battery charging.
or other mad electric faults
topscalcookie said:Has anybody had an abs light on dash stop the battery charging.
turnipsock said:That sounds like a corker, would love to hear the outcome.
cheers mate i'll look into that. i think it may be that or the light control relay its a 1990 w124 e300d. has the O V relay got a part notelevision said:Once again the Over voltage relay if faulty will light the ABS lamp and effect the idle and other circuits, let us have the car type and model for any more info.
malcolm
television said:Many years ago I repaired a Radiomoble radio for a customer's Rover 110, he came back the following week saying that he is always getting punctures now that I fixed the radio,and it must be something that I had done, never did solve that one.
Malcolm
topscalcookie said:cheers mate i'll look into that. i think it may be that or the light control relay its a 1990 w124 e300d. has the O V relay got a part no
Ian Brown said:Might have been the radio waves going through the tyres, :grin:
television said:Had not thought of that back then, could have been the long waves, they make bigger holes.
Some times I wish that I had retyred
malcolm
thanks tv i'll look into that but the relay is stuck to the sockets for now and i've got work tomorrow.I'll have a good go on saturdaytelevision said:To test, pin 30 is the 12volt in, pin 87 is the output under fault condition it drops to 7.5 volt normally dry solder but many crumble away if it is the original. it has a fuse on top, normally near the battery but could be in the main fuse box. there is no light relay
Malcolm
You should know by now that the lamp in the shed only lets the washing machine run on program 2.[/QUOTE said:that lamp in the shed controls me merc dash lights aswell
i'll let you know
