Electrical Gremlin and Suspension Bush query!
Status
Not open for further replies.
vidfletch
I have a 1988 W124 230TE. It has recently developed a strange electrical problem. When I switch the front windscreen wiper on, the reversing lights come on in time with the sweep of the wiper! This happens virtually everytime the wiper is used. Very occasionally it doesn't happen. I have checked the fuses and they are fine. I checked the reversing switch on the auto gearbox and it was firmly attached and dry. I found the engine to body earth lead and took it off cleaned it all and re-attached it. It still does it! I have taken out the reversing bulbs in the meantime and now of course all I get is the bulb failure light coming on and off instead. The wiper works as it should. The only other electrical problems which are minor but might help point the way for any of you experts is that my NSF window doesn't work (not the switch!), the heater control lights are out (haven't checked them yet) and also the heater always blows hot air irrespective of where the dials are. I can live with those problems in the meantime but I would rather my wiper and reversing lights were not having fun! Having looked at my untrusty Haynes manual the only link I can see between the two is an eventually shared earth but no direct wired link. Am I missing something?
The other query concerns suspension bushes. My car in common with others I have read about on here has a clonk on both sides at the front going over bumps. While underneath the car looking at the reverse switch I had a look at the bushes and shock absorbers. The shocks seem OK and are not leaking. The car also handles fine so I was quite happy with them. The lower ball joints look OK in so much they are not perished etc., and actually look quite new. The same goes for the Anti Roll bar bushes and track rod ends. I did notice that three of the four wishbone bushes were split and so obviously they will need replacing. I do not have the tools to "lever" the suspension to check for movement in all the bushes but visually this what I have seen. The car is due its MOT next month and while that will show up whats needed I would like to know some opinions so I can budget for the work needing done.
Any help would be most appreciated.
Vidfletch
MotardMan
Berkshire, UK
1995 E320T, S124, W124, Sportline
Anti roll bar bushes come in at about <£5 each, do all four of them.
As for the electrical problem, I have no idea! Sorry! I would suspect a wiring problem shorting the lights to ground or similar.
Heater problem may be the control unit (£35 or so 2nd hand), or the duo valve.
Window amy need a new regulator (£50 or so 2nd hand), I believe that Ford Scorpio ones are the same.
HTH,
Jim
Rog_E
Cambridgeshire
Re the wipers:
This sounds like a fault in the system that activates the rear wiper!
When reversing with the front wipers on the rear wiper activates, via the reversing light switch and a relay.
Check your relays and associated wiring!
andy_k
Bexhill On Sea, East Sussex
www.ak3dgfx.com
E55 AMG
could also be a re-run of the problem Jim had last week - check where the wiring loom comes out of the roof and into the rear door (passenger side door support) try unclipping that section and twisting it around - it's possible you have a couple of wires just touching each other. If that is the case, then split the casing and re-insulate the wires.
As for the "clunk" check the supports for the anti roll bars and have a good close look at them - there is one on either side "hanging" from the chassis consisting of a vertical bracket and a clamp. These have a tendency to split or stretch - replacement costs about £12 each from the dealers.
HTH
Andy
alec
Strange electrical problems often turn out to be to faulty earth connections . Check all the earth connections at the rear of the car.
Alec
Status
