Electrical issues/broken earth cable
dellyz
Registered
c300
Hello, lately ive been having strange electrical issues on my 09 C230:
Flickering cabin lights when first opening the door ( not when manually turning them on )
Strange static/crackling sound coming from front driver side speaker only ( others are fine )
Driver side turn signal will work for about 3-5 seconds initially, then the signal will blink rapidly and stop working ( in order to get the turn signal to work again for that 3-5 seconds i have to turn the car off and on )
Driver side emergency flasher does not work
Driver side parking light does not work
Passenger side parking light would not turn off until battery dead ( had to remove bulb )
Parasitic drain ( battery dead if not driven for 2 days )
Check engine light
Yesterday i saw this earth cable was broken
Could this grounding wire be the cause of those electrical issues?
Thank you
That cable is also pretty corroded so won't give a good earth (even when connected...)
ajlsl600
france
So much electric, electronics batts and connections of far more important than of old.
Craiglxviii
Cambs UK
Quite likely to contribute to many problems yes.
