My problems began with a flickering nearside headlight but has now started spreading to other areas so any help would be greatly appreciated, I initially replaced the bulb, then the igniter, then the ballast on the headlight all to no effect. Then this evening the lights in the passenger door for the seat controls side started flickering and this was followed by the script on the dash of 'consumer electronics offline' , which had randomly come up on it's own two days previously and me fully charging the rear battery.
There is also a smell that I would describe as similar to burning plastic in the engine bay, but for the life of me I cannot find where it may be coming from and this may in fact be hot oil from a slightly weepy rocker cover gasket?
I've checked for water in the airbox and the drains either side just ahead of the front windscreen suspecting possible water ingress but all these are clear, so if anybody has experienced this and can point me in the right direction it would be greatly appreciated.
