hi guys had some paint work done on my clk320 coupe2001 i went to pick it from paint shop they it would not start they charged battery but said it did not need much of a charge.when you turn the ignition the cooling fan comes on heater does not work and the boot will not open any ideas thanks mick
could be many things, my first guess is the seperate terminals are loose on the main live clamp at the battery. the fan running suggests the engine ecu is not powered up or has a comms problem.
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
