Engine cut out
SLK230
As soon as the engine is at operating temperature it cuts out and the car is imobilised . Also at that point the engine fan comes on and then the recirculating switch flashes as does the roof operating switch. Overnight the car will then start normally, then the cycle repeats itself yet again. When cold, disconnecting the thermal switch at the front of the engine reproduces the same fault . Any suggestions/comments would be greatly appreciated.2000 UK model.
Thank you
SLK230
  • #2
SLK230 - Cut out/Immobilised & non functioning roof
Good news M.B.A,s proprietor Barrington on tel;0800 2980039 has today competently , professionaly & resonably resolved all my SLK230's problem
and I am very happy to recommend him,by all means mention me & happy Merc' motoring Mike
SLK230
A block connector in the Module box in the engine compartment was at fault along with a loose Main fuse holder
www.ckinsurance.co.uk
