During Normal Engine Running The Engine Cuts Off As You Turn Off The Key.
Some One Can Helps Me In The Trouble On My C250td 1997????
Im a little confused to say the least. Could you explain this better
I've got this problem too, let me know what fixes it.
Sorry, when I can speak a second language then I can take the pee.
Sounds like a faulty ignition switch.I Have These Problems From Few Month And Are The Followings:
Sometime When I Turn The Key In Start Position Non All The Ligths Are On And If I Attempt To Put The Key In The Run Position The Engine Does Not Start ( Non Starter Crank).
In This Case I Turn The Key Off And Try Again And The Starting Process Is Regular , The Engine Start Regular And The Idle Is Regular.
Sometime During Engine Running While I Am Driving My Car The Engine Cuts Off. And I Have To Turn The Key In Off Position And Restart The Engine. When It Appened The Engine Restart Normally!!can You Help Me In Understandig Me What Appened????
