Engine Cutting Out Randomly W210
Bluegrass
W210 E320 Avantgarde 2000
For the past couple of months the engine randomly cuts out when stationary or starts →revs up and either cuts out instantly or slowly with the whole car shaking.Also whilst driving it feels like it's suffocating i.e not the normal amount of power readily available (if that makes sense).
This issue is very random. I could drive the whole day without any problems but on another day constantly cuts out, but it fires up instantly.
I have replaced the breather pipes, air filter and had a stab at cleaning the throttle plate in situ.the Now thinking of removing it and doing a proper clean. The fuel filter isn't too old and my mileage is very low 5000m a year, but will clean that also.
Anything else I could try before giving up and taking it to my "friendly" indie?
Thanks.
brandwooddixon
Wolverhampton
S63 Coupe 2014
I think that you'll be visiting an indie if the problem is intermittent.
A faulty cam sensor will cause the engine to cut out, but it doesn't always cause rough running, instead as it fails the engine will cut out when hot and restart when cold.
Another culprit would be a faulty MAF, but that usually causes rough running most of the time.
Bluegrass
Bluegrass
I don't think it's the Cam Sensor because it starts back up straight away i.e no waiting time needed to cool down. The Sensor it's about 4 months old though it might be poor quality product from ECP.
I suspect air leak but having changed all the breather pipes don't know where else to look.Fitted a new air filter from MB last month and notice a gap of about 1cm when in the holder. Don't know if this is normal. Never noticed it before.
Bluegrass
Bluegrass
I was wrong.
Bit the bullet and took it to the regular Indi I use. No fault codes showed up but at his suggestion changed the CPS and so far touch wood issue is gone.
Pleasant surprise was that he didn't charge me for the test.
Bluegrass
Bluegrass
Spoke too soon.
Problem is back.
giuseppe
Bournemouth
E220Cdi avantgaurde 2001
check the fuel valve regulator and sensor at the end of the high pressure rail near the bulk head, can get bunged up causing fuel starvation, a good dose of Stanadyne from dieselpartsdirect.co.uk will help to keep the fuel line and injectors clean
Bluegrass
Bluegrass
Is it the one next to the battery under the rear seat?
Bluegrass
Bluegrass
Do you have a picture or a link to one of this valve regulator & sensor?
Thanks.
Bluegrass
Bluegrass
No.
It is integrated into the K40 relay module in the fuse box under the hood.
Yes did that last year when the problem started following this guide.
Visually all solder points looked good and shiny but my soldering iron wasn't powerful enough to do a proper job.Maybe I need to have another go.
Bluegrass
Bluegrass
Thanks.
Found it. Will check when I have time. Browsing the internet this Valve Regulator seems a good suspect. Thanks.
Bluegrass
Bluegrass
Thought I knew where the Fuel Valve Regulator was. Can someone please point to it on this image.
mattkh
England
A160 W168 1999 1.6
Start at one end of the u-bending fuel rail. Feel below the rail. You are looking for a small saucepan looking thing attached to the fuel rail.
Bluegrass
Bluegrass
Thanks for your reply.
Just tried but unfortunately didn't find anything. Could this be it?
Forgot to mention before.Sometimes when this happens I hear a loud phuss sound like when a lorry breaks.
mattkh
England
A160 W168 1999 1.6
Yes, thats what they look like.
But to be sure, can you see any connection to the fuel carrying part.
Also, any part number you can read on it.
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
Does the W210 suffer from ECU/loom faults, dry joints etc? It's obviously getting on now, I may of course be barking up TWT.
That's not it. That looks like the variable intake operating diaphragm.
The M112 and M113 fuel pressure regulator is integrated into the fuel filter housing.
Bluegrass
Bluegrass
  • #19
Thanks for clearing it up. If it's integrated then I have no choice but to buy a whole filter.
I know it's recommended to buy parts from the dealer but since it's guess work can I get away with a cheaper brand? Have already spent about £500 for this problem.
Alex Green
Cl500/2000/V8 5.0L
My W215 CL500 had a similar issue and I changed the MAF and it is completely sorted now.
The engine ran well most of the time without any roughness but when cold would sometimes just cut out.
Turns out the Ford Ranger MAF is the same Bosch part number as the MAF on mine. Bought one for fault finding for £17 and problem solved.
HTH
AL.
Tel: 020 8863 9233
