Doc.
- Aug 23, 2021
- 2013 L3H2 Sprinter 313
Hi all.
Not been on here since just after my Daughter bought the Van (July 2021).
She was going to do a Camper Conversion, but then my first Grandchild came along, so that's been shelved.
It's not done a lot of miles since she got it, mostly me borrowing it for moving Motorbikes and DIY stuff around!
Anyway, it's just thrown the Engine Check Light.
My Topdon Diagnostic Tool shows the following DTC;
P2BAC ~ NOx Exceedance - Deactivation of EGR (both 'current' and 'stored' Codes)
Also, a System Scan brings up the Code;
P010315 Mass Air Flow Sensor 1 has a Short Circuit To Positive, there is a Circuit to Positive or an Open Circuit
I took it off and gave it a quick clean today, no change. Wasn't expecting it to rectify it, but thought it was worth a try.
12V at the Connector is good, as is the Ground/Earth.
I haven't done a Voltage check on the other Pin(s) to see if it changes with Revs yet, that's the next job.
Any 'quick' checks I can try, like running with the MAF disconnected?
Any other related areas to look at, Intake leaks, wiring damage?
Is the NOx/EGR fault likely to be connected to the MAF Fault?
Many thanks for your time.
