bwiggins
Hi I what to switch off engin management light off after repair E350 2010 I think it is a W212 can you help. Brian
What was the original fault ?Hi I what to switch off engin management light off after repair E350 2010 I think it is a W212 can you help. Brian
I think all EML need to be cleared when the problem is fixedSome faults don't latch the EML and will automatically clear if the fault is fixed
then there is a fault on the car - fixed correctly the light will be out and stay outMine pops on and off at will. No set time for on or time off. Gone through scan, codes, change parts but still comes on as it pleases. Anyway, in answer to your question. Any independant garage should switch it of for around a tenner, but if the fault is not fixed, it will return in a few days. Most DIY scanner will do this when you remove the fault code.
Thank you but not my post.then there is a fault on the car - fixed correctly the light will be out and stay out
might be a boost leak or from circa 2012 - you may need software updates to the engine mangement system - it "appears a few bugs are in there that accidentally" and the only way they go away is when Mercedes get caught and are legally ordered to remove them by the EU or USA, (opps I didn't mean to add the bold bit)
