Engine Management Light
whammer007
Hello all,
I got a call from the wife today saying that when she started the car this morning, it "shuddered" and the engine management light stayed on. Afraid to drive it, it remained idle all day until I got in from work. It started fine and idled OK, but the light remained on. I took it for a 5 mile run to heat it up properly, during which time it drove as normal. The light is still on even fter a restart.
My question is, assuming that the fault is no longer there (wishful thinking). Does the dealer (or suitably equipped garage) need to reset the light? Again assuming no codes are present, or is there a work around.
The car is a 02 plate W210 200 Kompressor manual estate.
Any help would be greatly appreciated.
Regards,
Whammer
scotty2hotty81
Sounds like you have a problem with your secondery air injection valve and also the wiring (z connector) common fault that would need to be done at your local mercedes garage, o.k to drive just get it sorted as of when.
W
whammer007
Can the light be reset in a DIY fashion?
