Engine Management :o(
emmamarie81
Afternoon
The diagnostic light on my 51 plate slk came on last friday and i have since noticed that the car is losing power.
its a 2litre kompressor and is very sluggish the last few days even when im in 1st, 2nd, and third gear!!!
Any1 else had this issue??
Em
dave.robbo
Gloucester
2004 SLK 350 R171
If the diagnostic light is on, then you need to take it to be put onto a STAR diagnostics machine.
That will tell you what's up with it..
E
emmamarie81
at my local mercedes garage i take it?
dave.robbo
Gloucester
2004 SLK 350 R171
Yes, or an indy (independant specialist) if you have one nearby.
Whereabouts are you?
E
emmamarie81
i am in swansea, i think there is one called sinclairs near here
dave.robbo
Gloucester
2004 SLK 350 R171
I think that would be your best bet, to start with..
I would think that this is where the cam seal has gone allowing oil to travel up the harness,into the MAF , this oil gets burnt and fouls the O2 sensor and this puts the light on.
New loom and seal, a common fault...ECU once washed always OK
Cole@MBS
www.mbssouthampton.co.uk
Falls into the right age and model for that fault Malc!!
