Engine Mounts. (god how exciting...)
sooper coop
Weybridge
Advice please.
Does replacing the engine mounts on 130k 300CE, make a really noticeable difference ?
£150 Job -ish ?
Parrot of Doom
Manchester
It will if your old ones are on the way out, especially if the engine starts moving around......
MerChris
Falkirk, Scotland
I have been advised to replace two of the engine mounts in my 300E after noticing that one end of the engine was quite a bit lower in the engine compartment than the other. This apparently applies excess pressure onto the chassis which of course is not good long term for the car. I have been given an estimate of £200+ all in for the job, based on around £65 per mounting pin and two hours labour.
Normally easy to replace, just jack the engine slip the old out, and the new in.thats it, just like that. sometimes I have just replaced the faulty one
Malcolm
merctronic
Banned
north west.
Malcolm
I think you will find they dont just slip in and out,,you will need to take the 17mm nuts off...
It was just a figure of speech,( or type in this case) of how easy it is to do
Malcolm
merctronic
Banned
north west.
Malcolm
i know mate,no harm done,but someone would have came in and made an issue out of it..lol
You are dead right they did
Malcolm
tom7035
If the alignment of the engine is suspect I would be more inclined to think of the rear mounting particularly (under the gearbox). Also easily replaced.
mjtray
Reading
sooper coop said:
Advice please.
£150 Job -ish ?
It is well worth spending the money....I've had them done recently on a 300E and on a 300CE and they made a noticeable difference to smoothness.
Also if you leave them too long they can end up causing exhaust manifold problems where they join to the down-pipes.
